Can someone let me know the pin out configuration for the autometer drive shaft speed sensor? I want to use it with my mega squirt ecm. What color is ground, power and signal? I cold not find it on their website. Thanks.
Liked 333 Times in 180 Posts
Black is ground white is signal red is power that's the way we always run it Fed
Thanks Fed!! Im going to reuse my cable also that went to my tach. The end of the jumper cable at the sensor has a three wire connector but the other end that goes by the tach has a 4 wire connector. Is the fourth pin a shield?
Ok, have the info I need. Ill post it here in case someone else will need it one day.
Connector has terminals marked A,B,C A -Blue is ground B- black is signal C- tan is 12 volts |
