Old 12-17-2017, 06:28 PM   #1
JeffM
Liked 5 Times in 5 Posts
Default SS transmissions, new and used LS parts
CSR SBC/BBC anodized red thermostat housing (912R) with spare o rings $50.00 - Used
Autometer electrical 100psi sending unit with 3ft of -3 braided line – $30 Used
Biondo Racing Terminator trans brake button (no shims)– Used $100.00
Computech Datamaxx data acquisition main module with harness. $350.00 used
Computech Datamaxx LCD screen $400.00 used
Powerglide transmission with stock case, ATI 1.98 S/S with coan 300m PG input. Stefs pan with heater, TCI brake, freshened by Defiance Transmission (Ken Shawver). Less than 20 passes on the new 1.98 gearset. $1350.00
Coan 350 Super lightweight transmission freshened from Coan in Dec 2015 and still in box. Coan brake, ceramic bearings, billet roller tail. Reverse pattern with clean neutral 2.30 first, 1.48 second ratios - $4400.00
Coan 350 transmission with brake 2.38 or 2.30 first gear $1500.00
Holley fuel rails pn 534-203 new $125.00
Cometic LS7 head gaskets (New/pr) 4.200 bore .056 PN H2462spb056s $100.00
Cometic LS7 head gaskets (New/pr) 4.200 bore .053 PN H2462spb053s $100.00
Cometic LS7 head gaskets (New/pr) 4.200 bore .060 PN H2462spb060s $100.00
Pac valve spring locators 1.270 x .640 x .520 x .060 PN PAC-S121 (dyno test only) set of 16 - $30.00
Pac valve spring locators 1.270 x .600 x .520 x .060 PN PAC-S128 (new open box) set of 16 - $45.00
Pac valve spring locators 1.270 x .615 x .575 PN PAC-S138 New set of 16 $175.00
Pac Titanium retainers 1.200 x .890 x 600 PN PAC-R532 (dyno test only) set of 16 - $250.00
Pac Titanium retainers 1.200 x .890 x 600 PN PAC-R432 (new open box) set of 16 - $170.00
Pac Tool steel retainers 1.250 x .890 x .600 PN PAC-R632 New set of 16 $260.00
Pac valve spring locks 8mm Mini8 +.050 PN L8142 new set of 16 $55.00
Pac titanium valve spring locks 5/16 Mini8 STD PN L8139 new set of 16 $125.00
Pac titanium valve spring locks 5/16 Mini8 +.050 PN L8123 new set of 16 $125.00
Pac titanium valve spring locks 5/16 Mini8 +.050 PN L8124 new set of 16 $125.00
Pac dual valve springs PN PAC-1237X – (dyno test only) set of 16 $225.00
Pac dual valve springs PN PAC-1238X – (dyno test only) set of 16 $225.00
Pac dual valve springs PN PAC-1335 – (dyno test only) set of 16 $225.00
Callies Compstar 6.100 LS rods with ARP 2000 bolts (dyno test only) $500.00
Callies Compstar 6.100 LS rods with ARP 2000 bolts (used) $350.00
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $550 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter – used $50.00
Meziere WN0032S – 1.50 diam water neck fitting black – $10.00
CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends – used but good condition – $30.00
Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends – used but good condition) $50
Trend 7/16 tapered pushrods (qty 16) 9.450 x .165 x 5/16 ends new - $100
Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $100
Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25
Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25
Comp Cams 3/8 pushrods (qty 16) 7.800 x .080 x 5/16 ends used - $25
pictures available upon request
superstock@live.com or 260-223-0157
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
