Old 11-14-2017, 12:45 PM   #1
Randall Klein
Liked 316 Times in 67 Posts
Default Stop Leak recommendation
Many have recommended DIKE, their video very impressive
Others?
Old 11-14-2017, 04:40 PM   #2
Wayne Kerr
Liked 26 Times in 11 Posts
Default Re: Stop Leak recommendation
Moroso Ceramic Seal.
See you at the races,
Wayne Kerr
Wayne Kerr is offline   Reply With Quote
Old 11-14-2017, 05:44 PM   #3
James Perrone
Liked 1,829 Times in 427 Posts
K&w. Block sealer.
james perrone 1290 STK
James Perrone is online now   Reply With Quote
Old 11-14-2017, 08:43 PM   #4
tomcraig
K seal
tomcraig is offline   Reply With Quote
Old 11-14-2017, 09:03 PM   #5
jerry witzel
jerry witzel's Avatar
Liked 44 Times in 15 Posts
Go to your local pharmacy and get some sodium silicate, also known as water glass.
Old 11-16-2017, 10:48 AM   #6
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Stop Leak recommendation
If you have any water getting into the oil, DON'T use water glass. It would combine with the water or coolant and make a compound that would be destructive. On da last Prezzdent's watch, when they were buying back old cars to destroy them so people would replace them with new ones, they put about a quart of that stuff in the oil,ran the motor to deliberately destroy it, then scrapped the car. The stuff formed sharp hard glass fragments which destroyed the bearings, crank, piston skirts,and the block. Just what the al gore's of the world want for all of us.
Old 11-16-2017, 01:36 PM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Subaru Cooling System Conditioner , part number 35071,[ they don't call it sealer for legal reasons] works fantastic for small leaks .
We used it for Jeep 4.7 engines with cracked heads and it rarely did not stop the leak , and most stayed sealed up for more than a year.
2 small bottles did the trick and it only costs $3.00 a bottle.
I use it on one of my Big Block Chevy engines with copper head gaskets ,completely stopped all the weeping ,even with a 12# cap
Old 11-16-2017, 05:27 PM   #8
House of Darts
Liked 20 Times in 15 Posts
I too have used the Subaru sealer and it was $2.00 per bottle. Great for ssssmall head gasket leakage. It is only meant for small leaks that Subaru had/has with their flimsy radiators. If you have a larger leak, then this may not work. British made product that resembles Bars.
House of Darts is offline   Reply With Quote
Old 11-19-2017, 05:23 PM   #9
tim worner
Liked 126 Times in 20 Posts
Dike
Tim Worner SS 1747
tim worner is offline   Reply With Quote
