Old 11-07-2017, 08:05 PM   #1
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Default New and used SBC Super Stock Engines
Used
350/300hp - apart - all in good shape - engine had about 100 total passes on it.
Bow Tie Block w/ billet splayed caps
GM steel crank - lightened
Manley Rods (standard journal)
BME pistons
Comp cams cam & lifters
Jesel belt drive and rocker arms
Gulius cylinder heads and intake
Complete manifold to pan
A good reliable consistent combo
Get it honed and reassemble
$ 8500 obo
Brand New
350 - L-98 EFI Complete Engine ready to go
Gulius built - same combo that Qualified #1 at the Dutch.
all the best parts / all brand new (including the block)
Bow Tie Block / .904 Crower Maximus Lifters / 55mm Cam
Jesel Belt Drive & Rockers / ATI Balancer
Custom Crank - Manley/Honda Rods
BME Gas-Ported Pistons
HRE Intake Manifold
Iron head / 270 nhra hp factor
#083 heads - test run prior to building the engine - NO LEAKS
Very versatile combo - fits many classes -
Injection programming and tune up info included
Complete EFI systems available if needed
Price lowered to $25,000
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 11-09-2017, 09:47 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Default Re: New and used SBC Super Stock Engines
Hi Angelo
I have a few questions on the used 350?
What head number and valve size?
Is this a flat top piston combo?
Is this the same as the 295/313 combo for a 67/68 Camaro?
Thanks!!
Mike Pearson 2485 SS
Old 11-09-2017, 11:01 PM   #3
Angelo DiTocco
Hi Angelo
Thanks!!
#041 casting number
1.94 valve
Yes flat-top piston
And yes - it's the 313hp in SS
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Old 11-10-2017, 09:05 AM   #4
Mike Pearson
Can you send me some pics of the engine parts and your contact info. Send to ssia2485@yahoo.com or text to 813-433-4742.
Thanks
Old 11-11-2017, 09:12 PM   #5
Angelo DiTocco
Will do
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
