Liked 77 Times in 15 Posts
1968 Stock Black Front Seats, Good condition (out of our Silver car). Available after Nov. 5th. $650
1968 396/325 BBC Armstrong Motor. Best you can build, 215 heads, this is the motor in our silver stick car (2017 Indy and Bristol Class Winner, Charlotte National event winner), about 75-100 runs (only ran 16-17 seasons). Complete, less carb. Available after Nov. 5th. $12,000 Performance Welding SS Headers for 396/325 67-69 Camaro. Collector and 8 O2 bungs, with PW teathers. Available after Nov. 5th, Ran for 1 season, $3600 new, will sell for $3000. McLeod Soft-Lok Copo Clutch BBC, built by Tim Hyatt, just like those in the new Copos, used (in the car for our Charlotte National event win) but ready to race, I would freshen while it is out. Disc is good, has about 50-75 runs. $1250 Several 396/325 290 small plug heads, $600 a set (I have 3 sets of these) Several 396/325 215 heads, $400 a set (I probably have 8 of these, not necessarily sets) Several 396/325 Intakes '948, $150 Several 396 Blocks, these are not machined, not raced. Probably stock, but you need to measure and inspect yourself. I have them for stocker builds, so they *should* be stock. These are not used race parts. Block Numbers, '291 std bore w/ the original screw in metal filter cover/housing, $750 Unsure of number, I think it is a '291, 2 bolt, standard bore as well. This and the above are my two best unused, $750 '323 block, 2 bolt, should be standard bore, $500 396 cranks (3). Surface rust from being in shed, good for the street. $75 each 396/375 BBC Davis Step Headers. They have PW tethers. Good condition. $500 Goodyear SS Slicks, 33x14.5-15, D0867, Stick Bias Ply Tire. Mounted, never ran, still have the stickers on them. 103.25 in measured when mounted. Two 1967/68/69 Dodge Dart Bodies, great for AH race car build. See add on ebay for details. $3,000 OBO. These need to go. https://www.ebay.com/itm/12277487032...84.m1558.l2649 No shipping on Heads, Blocks, Intakes, or Dart Bodies. If you PAY for anything, I can/will deliver it to you at the races in 2018. We attend races in Divisions 1, 2, and 3 every year. Contact Matt Welker 410-507-28three7 matt@welkerlawfirm.com Last edited by Matt Welker; 10-27-2017 at 11:14 AM. Reason: Add Item |
