Old 10-18-2017, 11:12 AM   #1
bert powell
Liked 34 Times in 12 Posts
Default Super Stock BBC Garage Cleanout
396/350 Parts- bought apart with 14 runs, kicked a rod. 290 heads done by Heads Up in 2009, one was cracked, had repaired but may want Heads Up to do another. Have most of original valves and all new Comp springs, Manley +.050 retainers and locks. Crower rods- 2 new, JE pistons- need 2, stock 6223 crank core. Armstrong Bullet cam, pushrods. Merlin ported intake. Extra used Venolia 2 ring pistons with new rings. $3k everything
402/300 Parts- Rotating assy with 5 dyno pulls- caught a main bearing and we went to smaller rod journals. GM crank by Shaftech- lightened, gun drilled and REM finish. Sent back and had mains turned and nitrided. Molnar LG SBC light rods. Diamond pistons/pins- coated top, Rebco lightening, .0415/.043/3mm. Have rings you could reuse, they were $800. $1800 everything
454 block sleeved down to 396- needs bored for 402. Filled and bushed. Had crack on side of block repaired and ran after. Was going to bore for 402 above but have Dart block now. $500- what I paid for it.
Jesel rockers- let me know what you are looking for. Misc coated bearings- let me know what you need. QJet cores and parts. Various cams-Bullet, LSM, Comp.
TH400- reverse manual, alum drums. 20 runs since freshened $1200
Complete 402/300 rated at 308. Originally built by Hettler, been updated. 26 runs since fresh, makes 650hp and runs 9.90s in GT/IA. Armstrong block-4 bolt, bushed lifters. GM crank, Oliver rods, JE pistons. Bullet cam by Warren, new Comp lifters, Jesel rockers and belt. Original Hettler heads and Dart intake. Solid engine that is heavy duty. $12k available after Rockingham.
Have pictures and can deliver to Rockingham.
bert powell is offline   Reply With Quote
Old 10-21-2017, 09:27 AM   #2
Makinchips
Default Re: Super Stock BBC Garage Cleanout
Interested please pm a number to call
Makinchips is offline   Reply With Quote
