Anyone recognize this builder?
Todd Greene |
Liked 8,021 Times in 1,526 Posts
Scott Welborn from SC worked on quite a few Q jets years ago...
Liked 5 Times in 4 Posts
Your car being from D-1 I would say Joe Scott
Could be Joe Scott from northern Pa
Thanks guys.
Todd Greene |
Liked 73 Times in 36 Posts
Look on the bottom of the throttle plate - If a Joe Scott piece, will be vibra penciled with Scott on the bottom and also the rear (with a number). Last one I worked on was #72 (that was probably at least 30+ yrs old) and also had a brazed secondary lever so all four throttle blades opened at the same time.
Regards, Dissident |
#7 | |
Todd Greene |
Also as an addendum, no the fuel system is probably not ideal (blue pump and holley regulator, deadhead) but the pressure is turned down to 5 to eliminate that as the rich condition.
Todd Greene |
