Old 09-15-2017, 09:28 AM   #1
RickMcCannGTCA
RickMcCannGTCA's Avatar
Question W/TH in NHRA classification?
Hi All,
hope you can help with our query. We have just finished preparing a 1970 Camaro with an LT1 and hope to be racing it here in Sweden in D/SA next season, but when establishing the legal weight we come across different shipping weights depending on whether it's a "coupe 2 door" or a "coupe 2 door W/TH.
I initially thought TH stood for TurboHydramatic, but the different weights appear also under "manual transmission", so what does the TH stand for?
350 350
auto manual
360 360
3341 3341
3397 3397
325 320
12.19.02 1.1.15
I would be very grateful if you can tell me the difference between the 3341 lbs and the 3397 lbs.
Thank you!
Last edited by RickMcCannGTCA; 09-15-2017 at 09:33 AM. Reason: incomplete description
RickMcCannGTCA is offline   Reply With Quote
Old 09-25-2017, 11:55 PM   #2
Greenlight
Liked 79 Times in 22 Posts
Default Re: W/TH in NHRA classification?
The w/TH does indicate an automatic transmission.
Dwight Southerland has kindly put together a website that is more user friendly than the NHRA classification guide and has all of the critical data.
Please register with Dwight on this website:
http://www.classracerinfo.com/Default.aspx
For your car (1970 Camaro 350 cid / 360 factory HP)
Shipping weight w/ MT = 3341lbs. NHRA P/W factor = 10.44 NHRA HP rating 320
Shipping weight w/ TH = 3397lbs. NHRA P/W factor = 10.45 NHRA HP rating 325
Min. Wt. w/ driver:
D/SA = 3258 lbs. (NHRA rounds down to 3255 lbs.)
E/SA = 3420 lbs.
F/SA = 3583 lbs. (NHRA 3580 lbs)
Greenlight is offline   Reply With Quote
Old 09-26-2017, 01:23 PM   #3
RickMcCannGTCA
Many thanks, that´s great.
Rick
