Old 09-01-2017, 07:55 PM   #1
Gregg Luneack
Liked 225 Times in 30 Posts
Default New & used parts
NEW Big Block Chevy Aluminum Heads, #1236401 $1600.00 pr
New Redline 427-425 Hp Solid lifter camshaft $ 275.00
NEW 400 cu in Chevy Crower Billet Rods, 548 grams
5.565 Length,.875 pin, SJ big end $975.00
New Moroso Aluminum Oil Pan 283-400, 9" rear sump $150.00
Used 12 bolt 6.17 Pro Gear, good condition $150.00
Used TCI 904 Mopar 8" converter, 5000 flash on low comp 340 $475.00
Used 904 Mopar 275 low gear set, good condition $ 250.00
NEW JE pistons, 70- 71 Mopar 440-6 pak, 4.388 bore
Legal stocker pistons, no pins. $750.00
New Moroso Mopar 383-440 electric water pump $185.00
Phone 760-630-9094
Gregg Luneack is offline   Reply With Quote
Old 09-01-2017, 08:49 PM   #2
hotrodbelair
Default Re: New & used parts
Do you have part # for the SBC Moroso pan? Thanks - Dan
hotrodbelair is offline   Reply With Quote
Old 09-02-2017, 11:09 PM   #3
Gregg Luneack
There is no part number, its the only one
they made out of aluminum.
Thanks, Gregg
Old 09-03-2017, 04:10 PM   #4
hotrodbelair
If possible could you send me a pic of the pan to hotrodbelair@aol.com . Thanks - Dan
Old 09-05-2017, 09:21 AM   #5
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Gregg you still have that new 6.17 pro gear for Dana 60?
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 09-06-2017, 01:00 AM   #6
Gregg Luneack
ED, 6.17 still available.
Thanks, Gregg
