Old 08-23-2007, 09:28 AM   #1
SSDiv6
Liked 1,604 Times in 583 Posts
Default Travis: Stock Class Crossmember Rule Interpretation
This one is for Travis or any one who knows:
In the rule book, Section 5A - Stock Cars, Oil Pan, a paragraph in the section reads as follows:
"...Crossmember may be altered for oil pan removal. If altered, all material and strength must be replaced by boxing or installing removable or permanent material"
Has any one done this type of modification to their cars?
Old 08-23-2007, 11:32 AM   #2
7820
7820's Avatar
Default Re: Travis: Stock Class Crossmember Rule Interpretation
In Division 7 Joel Larkin has done this to his first generation Firebird.
7820 is offline   Reply With Quote
Old 08-23-2007, 11:43 AM   #3
Tommy Gaynor
Tommy Gaynor's Avatar
Liked 5 Times in 3 Posts
done what?
Tommy Gaynor is offline   Reply With Quote
Old 08-23-2007, 05:22 PM   #4
7820
7820's Avatar
Joel removed the crossmember under his engine so he could pull his pan without removing the engine. He sliced out a section and then flanged everything so it could be bolted together.
Old 08-23-2007, 05:41 PM   #5
Tommy Gaynor
So is it legal to buy a bolt in tubular cross member for a late f body.
Old 08-23-2007, 08:35 PM   #6
REGGIE WINKLES
Liked 39 Times in 9 Posts
I don't think a tubular crossmember would work in stock and probably not in super stock..
Ed Quay has a nice piece that I know is legal in super stock and I think is OK in stock.
It is a modified factory piece and is not that expensive. If you send them your core it will
reduce the price. edquay.com
Reggie Winkles
4102 J/Stick
REGGIE WINKLES is offline   Reply With Quote
Old 08-24-2007, 12:32 AM   #7
Bernie Cunningham
Liked 52 Times in 17 Posts
Smile Re: Travis: Stock Class Crossmember Rule Interpretation
Tommy,
Ya' need to stop getting all worked up over stupid issues !! The rules say it can be done, IF YOU WANT TOO !! ( Our old buddy, Skelly, got it done) I did it during the past winter so I can pull my pan anytime I WANT and it's not a bad deal. You'll never know, when at a track, a problem can bite ya. I still have the templates for the boxing if you need 'em. ( for a 4th. gen) CM tube across the cut out piece and it bolts in. When I did it, nothing moved !!!!!!!!!!
B
Bernie Cunningham is offline   Reply With Quote
Old 08-24-2007, 07:23 AM   #8
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
So can a mod. like this (only bolt in) be done in a '70 GM "A" body?
http://www.trzmotorsports.com/images/gbodyrack/
Old 08-24-2007, 08:47 AM   #9
SSDiv6
Bob, based on Bernie's comment, the modification shown in your pictures may be acceptable...with the exception of the rack & pinion.
