Old 08-16-2017, 12:54 PM   #1
rx dealer
Liked 53 Times in 13 Posts
Default Copo 396 LS-3 and SB chevy parts
GM/Callies COPO 396 Crank 3.825 stroke # 19301270 std-std. Gun drilled mains and rod journal 58X wheel $795.00 or best
GM stage 3 hyd. roller cam # 88958773 $225.00
PSI max life beehive valve springs for GM stage 3 cam with retainers,cups and locks $150.00******SOLD*******
GM LS-9 rocker arms 1.7 ratio with stands and bolts $150.00
Trend double taper push rods 7.375 x .080 $110.00
8 COPO 396 Injectors same as ( LS-7 ) 43lb/hr @ 58PSI $200.00
GM 6 qt. cast oil pan with tray/pick up tube and bolts from COPO camaro $120.00
ARP Main studs for LS new in box. $ 225.00 **** SOLD*****
Hamburger #1061 brushed alum. valve covers with hardware for LS. will clear Jesel Rockers. New $200.00
MAHLE LS-3 Main Bearings MS2294H/ MS2294 HX/ MS2199HXK. new in box ***** SOLD*****
MAHLE LS-3 Rod Bearings CB 663HNK-1/ CB 663HXNK New in box ******SOLD*****
SB Chevy Parts
Used set of JE 350-255 super stock pistons .060, Lightened and new coated top and skirts .927 pin hole, Radial ports $300.00
Victor E super stock intake by heads up with Wilson Holley to Q-jet adapter. New $400.00 *******SOLD*******
Quick fuel Holley 750 DP. carb. $ 300.00
B/G 400 fuel pump works great comes with rebuilt kit and 4 port BG fuel regulator $275.00
MSD HVC 2 Coil # 8261 $125.00
Crane ultra lite Roller lifters $125.00
Hooker 3 step SBC headers for 93-02 Camaro-Firebird Super stock coated nice no dents $400.00
all COPO parts have 12 runs on them SBC parts are used not used up unless noted...make offer...Luke 248-342-3117
rx dealer is offline   Reply With Quote
Old 08-21-2017, 06:54 PM   #2
Rob Wright
Liked 21 Times in 7 Posts
Default Re: Copo 396 LS-3 and SB chevy parts
Have you sold the main bolts yet?
Rob Wright is offline   Reply With Quote
Old 08-22-2017, 02:39 PM   #3
rx dealer
Still have them.
Old 09-26-2017, 02:20 PM   #4
Rob Wright
Do you still have the lifters?
Old 09-28-2017, 08:52 PM   #5
rx dealer
Hi Rob. I do have them
