Old 08-15-2017, 09:43 PM   #1
jswoodfin
Default Holley EFI Help
We installed a Holley Dominator EFI system on our Altered and are struggling to reach the expected performance of this package. I realize an Altered isn't a legal Stock/Super Stock package, but I know that many of you have EFI experience.
I'm looking for an EFI expert/guru to review my data and provide feedback to improve the performance. I've had some help along the way, but believe we're missing a lot of power.
The 417 SBC "should" produce 900+ HP, but we're only getting 660 HP.
Who do you lean on when you need EFI help?
Thanks,
Jeff Woodfin
jswoodfin is offline   Reply With Quote
Old 08-15-2017, 10:01 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 973 Times in 310 Posts
Default Re: Holley EFI Help
Thanks,
Jeff Woodfin
Did you contact Holley?
Old 08-16-2017, 09:24 AM   #3
goldformula
Your location may help in directing you to a good shop.
I believe Holley has a list of approved dealers and installers.
goldformula is offline   Reply With Quote
Old 08-16-2017, 10:29 AM   #4
GUMP
Liked 2,354 Times in 554 Posts
I would get with Holley. They have some sharp people. Also, if you get the opportunity, their classes are worth attending.
GUMP is online now   Reply With Quote
Old 08-16-2017, 12:49 PM   #5
340Cuda
Liked 802 Times in 339 Posts
I would recommend Scott Clark.
He can give you immediate help. I would also recommend you attend one of his classes. They are a good value.
He can work with most anything, Holley, FuelTech, Megasquirt and others. He has tuned everything from Bonneville Cars to NHRA ProStock and more. He is a straight shooter and a good guy.
scott@realtuners.com
https://realtuners.com/
https://www.facebook.com/RealTuners-...1791515720605/
Good Luck!
Bill
Old 08-16-2017, 01:10 PM   #6
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Jeff,
There are a couple of guys on the Holley forum that will help you and also review your system. One of the guys has his own shop and knows his stuff and also races. Have you tuned it on a dyno? Also if you are not running an NTK O2 sensor that could be a source of poor performance. My standard O2 only lasted thru 2 dyno sessions and roughly 15 gallons of C16 when the motor fell on its face while testing. I already had an NTK and the motor came back to life.
There is a lot to be had with the timing and AFR tables, if your timing sync is not correct or stable thru the RPM range that may be another thing to look at.
Sean
Sean Marconette
84 Mustang
5060 SS/N
