Old 08-15-2017, 10:15 AM   #1
Shawn Pinkerton
Default 100% Street Legal 1967 Dodge Coronet NSS Replica
Car is period correct and will fit into any Nostalgia Super Stock event.
10.50's in the quarter mile w/o exhaust.
100% Rust Free, original Oklahoma car.
As seen on 2016 February Edition of Chrysler Power, 2010 Cover of Mopar Collectors Guide, 2010 Centerfold of Auto Enthusiast, 2009 Mopar Magazine. Signed by Mr. Norm and Don Garlits.
Professionally Built, custom Chrysler 440 big block.
4.350x3.075= 446 Cubic Inches
Stock Block w/ BCR Girdle system, Aluminum Caps
K1 4340 3.750 Stroke Cranshaft
Manley 14074-8 H-Beam rods
Wiseco Flat Top Pistons Approx 11.2 to 1(pistons have be lightened, skirts coated)
Milodon Oil Pan w/ external pick up
Mellings Race oil pump w/ spacer
new fluid dampener
Billet Timing Chain, 9 key crank
Comp Cams Hydraulic Flat tappet camshaft w/ 1.6 .545 LIft 246 degrees duration @ .050
Clevite V series Main Bearings
Clevite Rod Bearings HND Series
Total Seal-CR Series file fitting rings
Comp 928 Valve springs w/ locators
10 degree Titanium Retainers
Smith Brothers pushrods
INDY Cylinder S/R Aluminum Heads
INDY Cylinder Dual Plane Intake, professionally ported
INDY Cylinder 1.6 Rocker Arms, Shafts and Hold downs
All four shocks are CALVERT shocks
Super Stock leaf springs
Dana 60 by STRANGE Engineering w/ rear disc brakes, 4:55 gears w/ spool.
Wilwood Front Disc conversion, w/ line lock.
727 Transmission built by A&A Transmissions
A&A reverse manual valve body
Billet low reverse
Race Front pump
Billet Filter Extension
Kevlar 2nd Gear and low reverse bands
Ultimate 16 Roller Sprag (this trans can be set up for trans brake)
Billet Aluminum Low/Reverse Servo Kit
Billet Steel High gear drum
Turbo Action Converter
Holley 930 HP Carb currently on car
also included 800 AVS Style Edelbrock carb (100% NSS Approved)
Roll bar can be removed discretely, if wanted
Procar bucket seats to keep the NSS look
Turbo Action Cheetah shifter
Magna Fuel 500 fuel pump and filter
8 gal fuel cell
Magna Fuel regulator
MSD Distrubutor
MSD 6AL
CVR water pump
TTI 2" headers
Flowmaster 60 series mufflers w/ 2" exhaust
Both Bumpers are new restored
Small dent in drivers front eyebrow
This car looks as good as it does in pictures. You could not build a nicer B body to run these times cheaper.
Was $32,000. Price reduced $25,000.
Contact Kara Jo at 412-855-3992
Shawn Pinkerton is offline   Reply With Quote
Old 08-15-2017, 11:20 AM   #2
gymbo39
Default Re: 100% Street Legal 1967 Dodge Coronet NSS Replica
no pictures?
gymbo39 is offline   Reply With Quote
Old 08-15-2017, 02:30 PM   #3
Shawn Pinkerton
Can't add pictures here but if you give me your email I will be glad to send them or you can go to racingjunk.com and type ad number 182919626 into the search.
Thanks
