Old 08-12-2017, 11:57 PM   #1
Steve Starnes
Default Motor Oil
I live in Texas and have a 331 stroker I run 1/8 mile and drive on the street sometimes. I shift at 6300 any recommendations on motor oil?
Steve Starnes is offline   Reply With Quote
Old 08-13-2017, 08:16 AM   #2
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Default Re: Motor Oil
I would choose a weight that gives you 60 psi of oil pressure at 6300 RPM. Start with a 10w/30 and see what it provides. Engine components and clearance will dictate oil weight. I like the Brad Penn or Valvoline as they are easily attainable and tend to be a little cheaper.Post up your findings
The more people I meet the more I like my dog
Kevin
Old 08-13-2017, 09:47 AM   #3
Steve Starnes
I will, thanks thats good to know.
Old 08-13-2017, 10:00 AM   #4
Rory McNeil
I have a 331 SB Ford in my 4 speed bracket car, with a flat tappet solid lifter cam. Shift at 6800, 7200 thru the traps at 128 MPH. I have been using Brad Penn Penngrade 1 10-30 oil for years. Also use it in my 427 & 428 Ford FE flat tappet engines.Works great in my buddys solid roller engines as well.
NHRA 6390 STK
M/S 85 Mustang
