Old 08-21-2007, 11:02 AM   #1
ericsz
Default 10.5 tire on 8 inch rim????
Will this work ok or not?? I have 8 inch rims and am going to try 10.5 mickey thompson slick, will I have any issues?? Thanks!
Eric Bowling
ericsz is offline   Reply With Quote
Old 08-21-2007, 11:32 AM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: 10.5 tire on 8 inch rim????
Common practice is to use a rim about as wide as the tread. A lot of Stockers use 9" tires on 10" rims.
Too narrow of a rim and you have to use less air pressure to get full-width tread contact. But then the tire will want to wad-up more and could distort the tread area, punish the sidewalls more and possibly be less stable on the top end.
I'm not saying it won't work and some probably have done it, but I'd prefer not to. Each car/combo is different as to what works best or what you can get away with.
LOCOMOTION Racing
Old 08-21-2007, 09:02 PM   #3
castle5
Default Re: 10.5 tire on 8 inch rim????
ive run 10.5x 30 goodyears on 8 inch wheels for 17 yrs. never had a problem. run 10 lb. of air..1.46 60ft times 10.70 et.. i do run tubes because i always have...im old...
castle5 is offline   Reply With Quote
