Liked 11,007 Times in 2,263 Posts
I was working on a race car yesterday and noticed a daylight source in the trunk of the car. Who ever installed the rear fire wall did not do the job according to the safety standards in the NHRA rule book. Where the roll cage went through the package tray using the factory speaker holes, the fire wall was omitted. This would not be a problem until........things get out of control, and then its burn baby burn.
The point of this post is to bring attention to all racers that should be looking at their cars with a very critical eye. A good motto to use during inspection " That will do usually won't " With Tech reduced there will be fewer skilled eyes looking at our cars pointing out omissions that could affect the rest of our life. Be proactive on safety, your life may depend on it! Got to get back to work , Indy is only a few days away! |
Liked 118 Times in 41 Posts
Very good point Larry. But when installing the sheet metal around the bar you cant get it perfect. What is the best thing, (sealer), to use to fill in the gap?
U/SA 79 Mustang |
Liked 269 Times in 99 Posts
Cut a square or rectangle of the same sheet metal then cut a hole in it the same size as the roll bat tube, cut it in half then rivet it in place tight to the tube.
Liked 335 Times in 182 Posts
Flexible lip seal grommets from Kennard industries or McMaster Carr-also can use weatherstripping glued into place or a paintable sealer from auto paying supply
Liked 320 Times in 102 Posts
Red FireStop calk in a calking gun
Liked 1,985 Times in 598 Posts
The red fire stop caulk would not be a good choice. It does not have much of an adhesive quality. It is mostly a filler for non moving joints. I don't think it would stay in place in this application. There are some silicone based caulks that are fire rated. These can be obtained from a commercial sealant supplier
Mike Pearson 2485 SS |
Liked 8 Times in 4 Posts
The genius who decided tech is a waste of time and figured the organization could save money by cutting back on techmen has put racers in danger. Be warned that it is now up to you to look closer at your car and figure out how you can get hurt or worse. The extra set of eyes that could have possibly found a potentially dangerous issue is no longer looking at your car.
