Old 06-21-2017, 09:14 PM   #1
henrys57wagon
henrys57wagon's Avatar
Default steel trailer roof rusting
My old trailer roof is rusting and I'm looking to coat it and bed liner seems like a doable thing? Any other thoughts???
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 07-06-2017, 08:30 PM   #2
Chuck Westcott
Chuck Westcott's Avatar
Default Re: steel trailer roof rusting
Are you sure its Steel and not Galvanized Aluminum ?
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 07-06-2017, 08:54 PM   #3
FED 387
Liked 336 Times in 183 Posts
It's probably galvanized steel and the galvanizing has worn away hence the rust-- Best stuff I have found is KOOL SEAL ELASTOMERIC WHITE rubberized coating-- they use this on RV /Mobile home roofs a lot--- easy to apply follow the directions--- use a paint roller to apply--- after it dries if you have roof vents and seams along the edges go back with a paint brush and reapply to those areas-- seals the roofs seeps into the seams cures leaks AND it will probably drop the inside temperature in the trailer by 10-15 degrees because of its reflective nature( its white) Get it at most RV places look online Walmart used to sell it goes for about $17-20 USD per gallon however 5 gallon is usually a lot cheaper get it on sale for about $80--- 24 foot trailer takes about 5 gallons maybe a little less--FED 387
Old 07-06-2017, 09:50 PM   #4
voltdr
Liked 100 Times in 51 Posts
Definitely the best deal.
https://www.walmart.com/ip/Kool-Seal...1-Gal/17210942
Dan
voltdr is offline   Reply With Quote
Old 07-07-2017, 12:34 AM   #5
henrys57wagon
Yes galvanize has worn off. Thanks for the info. Will look into these products.
Old 07-18-2017, 05:54 PM   #6
jim hensley
For the price we pay for these trailers, I always was amazed that the trailer manufactures would not go the little extra and coat the roof with some kind of coating rather than leaving them bare metal. One of the biggest sources of black streaks also. I always coat mine first thing.
jim hensley is offline   Reply With Quote
