Old 06-04-2017, 09:22 PM   #1
Gregg Luneack
Liked 225 Times in 30 Posts
Default New & used parts
New 1 pr Big Block Chevy Aluminum Heads,guides already machined
for 3/8 valve stems, casting # 12363401 $1700.00
NEW 427/425hp Redline stocker camshaft $300.00
NEW 400 cu in Chevy Crower billet rods, 5.565 center to center
.875 pin hole, 548 grams, SJ big end $1000.00
NEW Moroso Aluminum oil pan 283-400 Chevy, 9 in deep
rear sump $150.00
New Dyna-Tech merge collectors, coated,2 1/8x3.400 chokex4.00 od $200.00
NEW PRO TRANS,never run, 264x158, clean neutral, all the best
parts no waiting, $4900.00
USED TCI 904 converter, 5000 flash on low comp 340, $600.002
USED 275 low gear set for 904 Mopar trans $250.00
NEW JE 440-6pack legal stocker pistons, 4.388 bore, no pins $800.00
USED 383-343 Mopar intake manifold 2x4bbl, casting # 1827899 $ 250.00
USED 64 Hemi single 4 bbl Magnesium intake manifold $650.00
USED 12 bolt 6.14 Pro Gear $175.00
760-630-9094 Thanks, Gregg
Gregg Luneack is offline   Reply With Quote
