Liked 53 Times in 16 Posts
Complete big pinion 4.86 axle assembly out of 2009 Drag Pak. 33 spline gun drilled axles, lightweight spool, 5/8 studs, strengthened Moser housing, billet yoke and anti-roll control bar. $1000.
Does this have the aluminum centre section?
It is not an aluminum case. It is a "489" heavy duty cast iron case. Came out of my 2009 Drag Pak after putting a nine inch in it for SS.
Where are you located?
In Ohio. John it is out of my Drag Pak, I put a 9 inch Ford in it when I went to SS and a trans brake. Keith Lynch 937-564-7991 if you need more info.
