Old 05-05-2017, 11:47 AM   #1
Comp 798
Comp 798's Avatar
Default Moroso Blue Max Spiral Core Race Wire Set
Moroso Blue Max Spiral Core Race Wire Set 72416 $132.50 new. I have 1 set Never Used $65.00 plus shipping. Set up by Sunset.
These wires are designed to be taken out of the box, plugged in, and raced. Each wire has numbered tags to identify cylinders and simplify installation. They're preterminated at both ends with the correct terminals and boots. They also have an insulated sleeve that runs the entire length of the wire and Sunset shrink tubing to seal the boots.
Check them out here: https://proshop.summitracing.com/parts/mor-72416
sam_tufano@hotmail.com
Sam Tufano
Last edited by Comp 798; 05-05-2017 at 04:08 PM. Reason: Set not sets. I have one set. Deleting the (s)
Comp 798 is offline   Reply With Quote
Old 05-05-2017, 04:14 PM   #2
nickh
nickh's Avatar
Liked 659 Times in 197 Posts
Default Re: Moroso Blue Max Spiral Core Race Wire Set
Sam I will take them, do you take paypal?
Old 05-06-2017, 09:33 AM   #3
Comp 798
Comp 798's Avatar
Sorry, I do not take PayPal. Check your PM. Thanks.....
Sam Tufano
Old 05-06-2017, 03:06 PM   #4
nickh
nickh's Avatar
Not a problem will mail you a money order.
Old 05-06-2017, 05:22 PM   #5
Comp 798
Comp 798's Avatar
Thank you. I will hold them for you.
Sam Tufano
Old 05-09-2017, 03:13 PM   #6
Comp 798
Comp 798's Avatar
nickh..... I have not received payment from you yet. No worry if you mailed it, but if not, let me know so I can make it available to someone else. Thanks.
Sam Tufano
Old 05-09-2017, 05:48 PM   #7
nickh
nickh's Avatar
Mailed it on Monday
Old 05-09-2017, 06:32 PM   #8
Comp 798
Comp 798's Avatar
Thanks.....
Sam Tufano
