Old 05-02-2017, 07:12 PM   #1
Comp 798
Comp 798's Avatar
Default Pro trans, tires, shocks, more
PRO TRANS TH350 W/ADJ. TRANS BRAKE, CLEAN NEUTRAL, P-R/N-1-2-3-N SHIFT PATTERN, STRAIGHT CUT GEARS 2.45 1.51 (E2), BILLET ALUMINUM ROTAING ASSEMBLY, ALL LIGHT WEIGHT COMPONENTS. OVER $7K NEW. USED 16 PASSES FROM NEW AND KEPT AS A SPARE. WILL MAKE SOMEONE A GREAT DEAL! 17 Spline Powerglide input shaft.
Everything listed next I will sell for 1/2 (50% or less) of the original price plus shipping:
Hoosier 18255 32.0/14.0/15L (Lightweight) C07 Drag Tires. 12 passes. $324.00 each new. $324.00 for the pair.
Koni Coil Over Rear Shocks 8212 1126SPA1 549.99 each new. Used for set up. Absolutely like new. $549.00 for the pair.
Coil Over Springs (for above shocks) 14' X 2.5" (inside diameter) 110# $62.99 each. $62.00 for the pair.
Aeromotive 11102 Pro Series Fuel Pump (Red) $779.99 new. Used one season. $350.00
Pushrods are new.
Comp Cams 8460-16 High Tech Chromoly 3/8" 7.800" .135 Wall (16) $206.50 new. $100.00
Manley 25834 4130 Swedged End Pro Series 3/8" 7.675" .080 Wall (8) $78.75 new. $40.00
Manley 25877 4130 Swedged End Pro Series 3/8" 7650" .080 Wall (8) $78.75 new. $40.00
All have 5/16" ends.
Moroso Blue Max Spiral Core Race Wire Sets 72416 $132.50 new. Never Used $65.00
FLO_FAST: 15 GALLON SYSTEM Includes Professional Pump, 15 gal. jug, Versa Cart & Strap Part # 31015
MSRP $489 new. $220.00 Check their website
http://flofast.com/flofastsystemstore.html
I have 2 Weight Boxes, 3 Weight Bars, Lead Ingots and Lead Shot for ballast.
email for photos: sam_tufano@hotmail.com
Sam Tufano
Comp 798 is offline   Reply With Quote
Old 05-02-2017, 11:51 PM   #2
Todd Bailey
Liked 33 Times in 17 Posts
Default Re: Pro trans, tires, shocks, more
Sam,
You have a PM.
Todd Bailey is offline   Reply With Quote
Old 05-03-2017, 04:17 PM   #3
Comp 798
Comp 798's Avatar
Todd..... I sent you an email
Sam Tufano
Old 05-05-2017, 07:11 AM   #4
sandi blair
Default give me a call
call me at 605-685-3046-Jim
sandi blair is offline   Reply With Quote
