Old 04-22-2017, 02:36 PM   #1
Wayne Scraba
Liked 186 Times in 48 Posts
Unhappy Selling Out...
Selling Out! I’m moving on and going a different direction in the hobby. Here’s my collection of high performance/drag race parts (all parts are New):
• Holley Dominator 80905HB – 1150 CFM - $1099
• Holley 80805HBX – 950HP Hard Core Race Double Pumper - $749
• Holley LS 3 Hi Ram & Dual 80802HBX 650HP Hard Core Race Double Pumper Carb Package - $1899
• MSD 7AL2-Plus Ignition System – $499
• Big Block Chevy Gasket Package, includes the following (all Mark IV) - $500
o Mr. Gasket 5362 Copper Head Gaskets (2 sets)
o Mr. Gasket 5802 Ultra Seal Head Gaskets (2 sets)
o Mr. Gasket 4405 Cam Change Gasket Set
o Mr. Gasket 5828 Ultra Seal Rectangle Port Intake Gaskets (2 sets)
o Mr. Gasket 5883 Ultra Seal Oil Pan Gaskets (2 sets)
o Mr. Gasket 5912 Ultra Seal Header Gaskets
o Mr. Gasket 5910 Ultra Seal Header Gaskets
o Mr. Gasket 153 Header Gaskets
o Mr. Gasket 5878 Ultra Seal Valve Cover Gaskets (3 sets)
o Mr. Gasket 5862 Ultra Seal Valve Cover Gaskets (3 sets)
o Mr. Gasket 182 Valve Cover Gaskets (3 sets)
o Mr. Gasket 90A Timing Cover Gaskets (2 sets)
o Mr. Gasket 94 Timing Cover Gaskets (2 sets)
o Brodix MG2001 Intake Gaskets (BB-2 Xtra)
o Fel Pro 1804 Oil Pan Set
• Holley Ultra HP Big Block Chevy Mechanical Fuel Pump #454-40 - $449
• XS Power S3400 AGM Batttery + Jerry Bickel Race Cars Custom Mount Package - $339
• Holley Ultra HP Big Block Chevy Mechanical Fuel Pump #454-25 - $289
• Earl's 60 Row Narrow Cooler #26000ERL & Earl’s 1302 Mount Kit - $289
• Earl's 42 Row Narrow Cooler #24200ERL & Earl’s 1302 Mount Kit - $249
• MSD #8551 Chevy V8 Pro Billet Distributor - $239
• Holley # 12-865 HP Billet 4-Port Fuel Pressure Regulator - $199
• Lunati Chevy EDM Solid Lifter Set - $199
• McLeod Chevy Mini Starter - $179
• XS Power Custom Heavy Duty Trunk Mount Battery Cable Kit - $169
• Crane 13977-1 Pro Series Timing Chain Set. Big Block Chevy - $149
• Holley #8 AN Dual Feed Fuel Line XP Carbs - #34-44 - $129
• Holley # 12-843 HP Billet Fuel Pressure Regulator - $119
• Holley #8 AN Dual Feed Fuel Line XP Carbs - #34-43 - $116
• Moroso Blue Max Spiral Core Wire Spool # 73230 (missing approximately 10-feet) - $99
• MSD #30829 Super Conductor Wire Set - BB Chevy w/ Crab Cap - $89
• MSD #31223 Super Conductor Wire Set - 90-degree boots - $79
• Jerry Bickel Race Cars Chrome Moly Battery Mount Kit - $79
• Holley 260 GPH Dominator Fuel Filter #162-571 - $85
• Street Wire 1/0 Battery Cable Kit (10-feet) Fine Strand Annealed Copper Street Wire - $69
• XS Power Lightweight Trunk Mount Battery Cable Kit # RK2GA-1 - $69
• Holley Billet Regulator Mount - 4150 Carburetor - #20-120 - $70
• Jerry Bickel Race Cars Cable Throttle Linkage Kit - 36-inch - $69
• Small Block Chevy Pro Topline 2.15-Inch Stainless Steel Intake Valves, set of 4 - $59
• Small Block Chevy Pro Topline 2.02-Inch Stainless Steel Intake Valves - $59
• Holley Carb Kit for 4150 Ultra XP Carburetors (I have two of these kits) # 37-1548 - $55
• McLeod Racing 16010 Clutch Release Bearing (GM short configuration) - $55
• Small Block Chevy Pro Topline 1.60-Inch Stainless Steel Exhaust Valves - $49
• MSD Blaster SS Coil #8207 - $49
• XS Power Big 3 1-0 Power Cell Battery Cable Kit #BIG#-RD - $44
• PerTronix 708190 Spark Plug Wires Flame-Thrower Spiral Core Stock Appearing - $44
• Holley 4160 to 4150 Conversion Kit # 34-13 - $44
• Holley Mechanical Choke Cable 45-228 & Mount Hardware # 45-229 Package - $44
• Hooker Headers 3.5" Reducers - #11036HKR - $33
• Moroso Four-Hole Laminated Wood Carb Spacer # 64943 - $30
• Jerry Bickel Race Cars 125 Amp Battery Shut Off Switch - $29
• Hooker Headers Slip Fit 4" Reducers - #11138HKR - $29
• Hooker Headers Slip Fit 3.5” Reducers - #11136HKR - $29
• MSD Chevy V8 Socket Distributor Cap #8437 - $22
• Crane Cams Teflon Valve Stem Seals for 3/8-inch Valve #99822-16 (I have two sets) - $19/set
• Hooker Headers 3.5" Weld On Collector Ring (I have two sets) - #11435HKR - $19/set
• Adding soon: Jesel Belt Drive – BBC Mark IV; Jesel Chevy .905 drop in lifters: Jesel Rocker Kit BBC AFR Magnum Heads; Holley LS3 tunnel Ram (2X4BBL carburetor); large collection of Aurora Rod ends.
Please contact me for photos of any of the above or for more detailed info.
SHIPPING -- Please Note: I’ll pay the shipping (anywhere in Canada or Continental USA) on anything over $100, except the XS Power battery kit and the XS Power battery cable kits.
Wayne Scraba is offline   Reply With Quote
Old 04-30-2017, 11:54 AM   #2
c5famer
Default Re: Selling Out...
Any pictures of the Jessel AFR rocker kit? and price?
Thanks, Jerry
c5famer is offline   Reply With Quote
