Old 04-14-2017, 11:23 AM   #1
john ancona
john ancona's Avatar
Liked 187 Times in 58 Posts
Default 850 Edelbrock 1910 Q-Jet
Help please, I have a Edelbrock Q-Jet 1910 with one to one secondary's on a 454 H0 with a dual plane intake and it works fine running down the track, I have drilled the vacuum break part # 05883 from .020 to .028 and I am still unable to get the secondary's to open enough on the burn out, so I removed the secondary damping link and it helped, but the secondary's still do not open quick enough on the burn out.
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
Old 04-14-2017, 03:31 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: 850 Edelbrock 1910 Q-Jet
I would put the link back on and carefully adjust the spring wrap on the secondary air valve . You shouldn't have any problems with a Q-jet on a 454 doing a burnout .
