Liked 18 Times in 2 Posts
1 - Mcleod 10" Soft Touch including pressure plate, Aluminum 157 tooth small block Ford flywheel and 3 clutch disks. $1,100.00 OBO
1 - Boninfante 6" dual disk including pressure plate, Aluminum 157 tooth small block Ford flywheel, floater, 4 disks and set-up tool. $1,700.00 OBO Contact Dick Lux. 210-861-3620 Last edited by dlux; 05-02-2017 at 11:57 AM. |
Dick, on the McLeod Soft Lok, is the clutch fresh, or how many runs on it? What spline are the discs, and are they all new or....? Is the flywheel zero balanced, 28 or 50 oz imbalance?
Clutchs are 18 spline and all have been used from 30 - 70 runs. The flywheel and pressure plate probably need to be resurfaced since I drove through the clutch st Gainsville. My engines are all internally balanced so yes the whole assembly is zero balanced. The pressure plate has probably 150-175 runs. Thanks for your interest. D Lux
