Old 03-27-2017, 05:57 PM   #1
J&S Racing
Liked 319 Times in 82 Posts
Default 69 camaro rag joint
Anybody have a idea what's going on here??
Is there a length difference in columns power to manual?
Old 03-27-2017, 07:48 PM   #2
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Default Re: 69 camaro rag joint
You should be able to gently tap the column flange into place. It slides out, and fasten with the 5/16NF & 3/8NF hex nuts and bolts along with the reinforcement washers supplied with the rag joint when purchased. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 03-28-2017, 05:37 AM   #3
J&S Racing
Tried that with no luck. Is it possible to slide the whole column down?
I have another column floating around. I'll check if that flange will slide out.
I will post everything in my build thread but it's been a challenge to get the steering situated
Old 03-28-2017, 10:44 AM   #4
FED 387
Liked 333 Times in 180 Posts
Rag joint(steering coupler)-- for 67-69 manual steering is GM # 7806391 pinch bolt is 7807271---Fed 387
Old 03-28-2017, 10:50 AM   #5
FED 387
67-69 Camaro PS rag joint is 7806390--Fed 387
Old 03-30-2017, 10:11 AM   #6
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
ps boxes have different size splines/shafts that manual boxes.
is that a manual Camaro box or a vega?
Old 03-30-2017, 11:44 AM   #7
J&S Racing
It is a camaro manual box.
I found some measurements online and it looks like the column shaft is pushed in about 1/4".
Old 03-30-2017, 12:24 PM   #8
cad
cad's Avatar
Liked 91 Times in 51 Posts
When I switched over to a manual box from another Camaro, I believe I had to change the rag joint. But I dont recall a gap.
From rockauto.com:
LARES 200 New; 3.25" OD Info
For 3/4" 25 spline input shafts with flat and 3-1/4" OD steering coupling assembly.
LARES 201 New; For 13/16" 31 spline input shafts with flat and 3-1/4" OD coupler. Info
LARES 202 New; For 3/4" 36 spline full round input shafts with 3-1/4" OD coupler. Info
Clark
Old 03-30-2017, 01:15 PM   #9
Camarob859
Liked 8 Times in 3 Posts
It's the Lares 202 , just did this on my car
Camarob859 is offline   Reply With Quote
Old 03-30-2017, 01:19 PM   #10
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Thanks for all this information . I didn't know the difference was in the rag joint . I have always gotten a manual box with the joint on it , so everything fit .
