Old 03-28-2007, 10:17 AM   #1
mannymen
Liked 13 Times in 7 Posts
Default Grade Point ?
Can you preregister for a divisional event?
If I'm pre-registered and payed in full, but can't make it to the divisional event for one reason or another, will I still receive my grade point?
Thanks
N/A
mannymen is offline   Reply With Quote
Old 03-28-2007, 10:33 AM   #2
G Schenck
Liked 81 Times in 35 Posts
Default
You should have to be tecked in, but I think different divs have different rules.
Greg
G Schenck is offline   Reply With Quote
Old 03-28-2007, 01:00 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Default
Mannynen,
I have never heard of preregistering for a Divisional race in ANY division.
In order to geta grade point you must at least tech a car in at the race. Thbis rule was implimented in order to prevent racers from "buying" a grade point.
Jim Wahl
6 Time National record Holder
2239 BF/S
I miss Buster Couch also! 'cause Div.2 will always be "Buster's Rebels"
Old 03-28-2007, 01:12 PM   #4
mannymen
Default
Thanks for your responses
Manny
N/A
Old 03-28-2007, 02:13 PM   #5
Bushwacker
Default
Who cares if they buy a grade point. free money Help keep cost down.
Ford-Lite
Half the Cylinders & No Carbs
Bushwacker is offline   Reply With Quote
Old 03-28-2007, 02:14 PM   #6
John Kelley
Default
The alcohol dragsters and funny cars can preregister to get free admission. And be used in advertising for the race....But I believe others enter when they get there and must make a qualifying pass too get any points.You gotta be on the qualifying list.
John Kelley is offline   Reply With Quote
Old 03-28-2007, 03:59 PM   #7
G Schenck
Default
You only need to tech in. A driver receives 10 points and one grade.
Greg
Old 03-28-2007, 07:05 PM   #8
John Kelley
Default
You're right....from page 250 of the 2007 NHRA rule book.
"All remaining event non-qualifiers or "no-shows" in eliminations will automatically recieve 10 points.A minimum of 10 points will be awarded to all contestants upon completion of event tech inspection and registration."
So you don't have to make a run ! Tech in a rental car,get the points and go home ! :-)
Old 03-29-2007, 12:21 PM   #9
Default
Approved helmet required to pass tech . Also a driveshaft safety loop is required on all RWD cars.
Blue Streak Promotions
Old 03-29-2007, 02:26 PM   #10
Bushwacker
Default
I showed up at montgomery a couple years ago with my daily driver 2000
F150 & teched in I told them I just needed a grading point...they said fine
but dont even think about making a pass down the track.....I said OK bye see ya later thanks for the grading pont.
Ford-Lite
