Old 03-16-2017, 02:40 PM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Header tube for 327-350
What length do most use for the primary pipe for each engine and collectors
Old 03-17-2017, 04:19 PM   #2
Coleydog
Default Re: Header tube size for 327-350
Must be top secret. Or there's not a Chevy on this site.
Old 03-17-2017, 04:34 PM   #3
SSDiv6
Default Re: Header tube for 327-350
You will not get a straight answer because the question is open ended.
There are too many variations of Chevy 327 and 350 engines throughout the years. Some 2-bbl and others 4-bbl, not taking into account the FI engines.
The requirements are also effected by the type of cylinder head, compression and camshaft specs.
If you have a specific engine year and horsepower rating, you might get a response.
I you are curious, you can also purchase a copy of the PipeMax software and put your specs and it will break down the header requirements for the particular data you enter.
Old 03-17-2017, 07:14 PM   #4
monte385
Liked 27 Times in 19 Posts
Burns stainless has a form you can fill out & they will give a recommendation, for a price I think, & yes Pipemax.
4-2-1 or 4 into 1? I built a set of 4-2-1 for my 421 street engine but never tested against anything else.
monte385 is offline   Reply With Quote
Old 03-18-2017, 03:17 PM   #5
Coleydog
Just remembered I have an old "Smokey" book, I'll reference that. Thanks anyway.
Old 03-18-2017, 06:44 PM   #6
Alan Nyhus
Liked 800 Times in 237 Posts
What's your combination? -Al
"That'll never work....."
Old 03-18-2017, 08:46 PM   #7
I try to answer most questions, provided I have useful input.
However, if the question does not include anywhere near enough information to allow for a useful answer, I usually simply do not have time to write out a list of things needed to give a useful answer.
Old 03-18-2017, 09:38 PM   #8
Coleydog
Ok... I don't think the tube length on my 340 Engine is right, I think they build too long a pipe. All I want is just a general size for the 3.25-3.5 stroke crank, since after 60 years someone should have it pretty close give or take a few inches, not trying to fine tune to the 1/4 inch. How about 66-327 Chevy 2, 69 Z-28 302, 70-1/2 Camero Z28-350, all running stock. I had off the shelf pipes on them then but can remember what size after all this time. Just a good starting point to compare. Thank you
Old 03-18-2017, 10:09 PM   #9
rboyle
rboyle's Avatar
Liked 602 Times in 165 Posts
I use off the shelf Dynatech steps 1 5/8" primaries to a 3" collector. I'm sure there's more power to be found
Old 03-19-2017, 12:33 AM   #10
ron mattson
Liked 69 Times in 32 Posts
1-5/8 to 1-3/4 14-16 inches of each
With a merge collector for a 4 to 1 set up
or 1-1/2 to 1-5/8 for a tri-y will get you
In the game.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
