Old 03-03-2017, 01:10 PM   #1
sst1226
sst1226's Avatar
Liked 11 Times in 2 Posts
Default 69 Nova Front End Alignment Question
69 Nova back-half ladder bar car with stock front clip. I just replaced the steering box and drag link, tie rods idler arm etc. I need to get it aligned, but also need to replace the rear shocks (coil over QA-1s) and would like to replace the rod-end/heim joints on the ladder bars while I’m at it. I plan on scaling the car out to get an idea of pre-load etc.
My question is, do I align the front end first and then scale the car out and replace the rear shocks, rod-ends etc or the other way around?
Doing a search on here it looks like alignment should be the following:
Camber = 0
Caster= 5 degrees, the more, the better
Toe=0 or 1/16” in
Car is raised 2-3 inches with driver weight in the seat
Is this correct and can anyone recommend a place near Delaware for the alignment?
Mario DiTeodoro III SST/SG1226 STK126M
sst1226 is offline   Reply With Quote
