Old 02-21-2017, 08:37 PM   #1
Jeff Teuton
Liked 325 Times in 50 Posts
Default Stuff
Several DP motors, 6.1, 5.7 most new never started, couple with dyno time only, a DP short block or two, a couple T350 Pro Trans. One never run and one with time. Pick your ratios. Both elec shift, reverse pattern, clean neutral. best stuff you can buy, 6.4 crank and pistons, new (convert 6.1 to 6.4) ask if you don't see it, DP stuff mostly. Maybe a 350 converter, maybe some more.
Jeff Teuton 4022 STK
