Liked 8 Times in 3 Posts
MSD 7AL2 - this was our spare box. Used it this winter. $275 OBO
MSD Pro Power Coil Part #8201. Brand New never used. $150 OBO Manley 221448-16 Used valve springs, 10 degree Titanium Retainers, OD Spring Cups. Has 74 drag race runs. Tested with (Rimac Tester) now 325# @2.100" $300 OBO Rossler Valve Body, Full Manual, Reverse Pattern PRN123, Chevy, TH400, Removed from Rossler TH-400, replaced with clean neutral valve body reason for sale! This is in like new condition with all hardware need to install and with instruction sheet. Air Shifter also available. $175.00 OBO Hurst Quarter Stick II Shifter for turbo 3 speed shift with solenoids and cable. Complete hands free shifting. Select each RPM for each gear shift! Also includes ADC Shift Control Box. Upgrades any single RPM CO2 shifter for Turbo Action & any other single solenoid (A & E, Biondo, Dedenbear etc.) Allow 1-2 and 2-3 shifts at different or the same shift point Box shuts off after the 2-3 shift for users wanting to go for a clean neutral. Using in my Super Stock car now, works perfectly. Won US Nationals @ Indy this year using this shifter,changing because of different transmission for 2017 race season! $350 OBO Strange pro gear 9" Ford. 5.67 ratio lightened. 54 runs on gear. Asking $250 OBO Ultra Strange Center Section with Billet aluminum caps, Mark Williams light weight spool, Billet aluminum tapered pinion support, Strange lightened 5.43 gear, chrome moly 1350 u-joint. 57 runs on complete center section. Asking $1500 OBO Chevy 434ci 750hp Shafiroff short block Chevy Bow tie block Jeff Johnson alum.oil pan System 1 oil filter Jesel belt drive Jesel rocker arms Msd front drive distributor Msd crank trigger Edelbrock super victor Demon carb. AFR heads Alum.valve covers All it needs is push rods,water pump ,starter DYNO time only! SOLD!!! Call or Text Ryan Haag 502-727-1035
Ryan Haag SS/EA 3750 E/SA 3750 Last edited by Ryan_Haag; 03-14-2017 at 08:20 PM. Reason: Added item. Item sold |
