Old 08-08-2007, 12:17 PM   #1
SSDiv6
Default Will this new Chevy engine be legal in SS Modified??
How soon we may see this new Chevy engine in the SS Modified ranks???
http://www.sae.org/images/enewslette...ain/03_455.jpg
http://www.sae.org/automag/technewsl...ertrain/03.htm
Old 08-08-2007, 02:42 PM   #2
Tommy Gaynor
Tommy Gaynor's Avatar
Liked 5 Times in 3 Posts
Default Re: Will this new Chevy engine be legal in SS Modified??
Try and get your hands on one, it will be a while!
Tommy Gaynor is offline   Reply With Quote
Old 08-09-2007, 10:06 PM   #3
Gary Smith
Gary Smith's Avatar
Liked 132 Times in 30 Posts
Default Toyota?
Sure looks like the bogus Toyota package, at least from the outside. Toyota's nothing more than homogenized Ford/Yates and SBC SB2 engineering. This new SBC looks alot like a Ford 385 series combined with 351C. Rumor has it the NASCAR master plan is to have generic V8 design for all manufactures. And like the bodies, the only separation would be the nameplate.
My question is, what does the future hold for traditional OHV engines? Or parts availability for that matter? Ford's push has gone to the modular OHC motors, judging by their current parts program.
Gary Smith is offline   Reply With Quote
Old 08-09-2007, 11:10 PM   #4
I looked at the Toyota engine, the block looks a lot more like a Chrysler NASCAR block than anything Ford. The heads do somewhat resemble an SB 2 setup.
I looked at an R07, it does not remind me of a Cleveland or a 385 BBF either one, except for the front mount distributor. Looks a lot more LSX/shrunken Rat than anything else.
Allowed to evolve, they'll all look a lot alike, because they're designed for the same purpose, under the same rules.
Old 08-09-2007, 11:15 PM   #5
G Schenck
Liked 81 Times in 35 Posts
must retain OEM bore spacing. What does that mean? Pro Stock does not have OEM bore spacing but they run those engines in comp.
Greg
G Schenck is offline   Reply With Quote
Old 08-09-2007, 11:36 PM   #6
Greg
Sort of a vague rule it seems. I guess if you read it one way, if an OEM made (or maybe just sold under their part number) the block, then the spacing is OEM, unless you modify it. I was thinking that NHRA finally put a limit on Pro Stock at either 4.9" (I think that's correct) or 5.0".
It remains to be seen whether the R07 makes substantially more power, or is just more durable and easier to work with, and has a small HP increase. I think if it had a great deal more HP potential, and NASCAR could see it, they'd have never let it in. Remember how much trouble GM had getting the SB 2 and SB 2.2 stuff in?
Of course, I'm not real convinced that the current bunch running NASCAR is exactly the sharpest knife in the drawer when it comes to doing anything but screwing up, and trying to squeeze another dollar out of their gullible spectators.
Old 08-10-2007, 11:57 AM   #7
Oclk Dlux
Smile Re: Will this new Chevy engine be legal in SS Modified??
Originally Posted by Steve Polhill View Post
Aparently according to him if you move the distributor to the front for easier access, everything in that motor must be copying Ford
My friend had a '73 Buick Century with a 350 and the dist was in the front. Also, all the late '60s/early '70s Caddies I've owned all had their distrubitors in the front as well.
Now, if Chevy moved the crank thrust bearing to the middle, then I'd say they were copying Ford.
Rich Hedden
6011 BF/S
Oclk Dlux is offline   Reply With Quote
Old 08-10-2007, 01:59 PM   #8
Michael Lyons
Hell if you can get one, just put it in your car. Bore spacing smore spacing, all ya need is a buddy in tech and he'll let you slide and then when someone figures it out and bitches or theatens to tear you down, NHRA will just make a rule change legalizing what use to be illegal and screw everyone with a legal engine right up their ***'es to the tune of tens of thousands of dollars because now you can't sell that obsolete piece and you absolutely have to have the new piece to be remotely competitive.. way to go, my beloved NHRA... So run whatever you want, that silly rulebook is merely a suggestion.
Michael Lyons is offline   Reply With Quote
