Old 01-31-2017, 10:17 PM   #1
Tom Meyer
Liked 354 Times in 120 Posts
Default LS 1 Valve train adjustment
What is best way to set up lifters and valve adjustment on a LS 1 stocker motor. Do you shim the lifters, what about adjustable push rods, rocker arms. This stocker stuff is kicking my butt. Tom
Tom Meyer 5240 SS Stock ???
Old 01-31-2017, 11:21 PM   #2
Todd Gross
Liked 54 Times in 24 Posts
Default Re: LS 1 Valve train adjustment
Hi Tom, On the LS7's I have been using Manton / Jesel shim- adjustable push rods with short travel roller hydraulic lifters.
With the rule change this year allowing the solid roller lifters we are changing to T&D adjustable rocker arms to use with the solid lifters.
Both are expensive. The Push rod kit cost about $700 a few years ago.
The T&D are about double that. Maybe someone will chime in with a cheaper alternative.
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 02-01-2017, 02:48 PM   #3
Tom Meyer
Thanks. We are going to go with adjustable rockers and save the hassle. Will post CHE trunnion upgrade on classified. Tom
