Liked 53 Times in 38 Posts
Im ready to do a ballest box in the car and need some insight on how and where one puts it, photos would help. I know the rule book explains this but kinda vague to me and whatever you guys have made does work. What's used for weight? Lead? I guess it would have to be removable or added to go up and down a class, right? Any help would be appreciated.
Oh yea forgot to add, I want to incorporate this into the rear cage bars if possible. |
Liked 13 Times in 10 Posts
what kind of car? i have good pics for gen 3 camaros and gen 1 camaros
Liked 759 Times in 379 Posts
Liked 276 Times in 27 Posts
When asked by a racer about weight in the box, I suggest using units of 10 lbs each such as lead. Set the car up with 50 lbs in the box. As you go from track to track if the scales vary, up to 50 lbs can easily be added or removed.
I took the rule book to my friend's fab shop, had him build me one to those specs. Looks just like the picture in the rule book. Bought 25lb bags of lead shot at Bass Pro Shop. Made myself a ten & 15 lb bag of shot, and a 5 lb bag. I can adjust for scales anywhere I go.
Ed Wright 4156 SS/JA |
Thanks, good info so far, never had to worry about adding or subtracting weight before in a race car. How is the box attached,to floor, frame, high, low? Figuring out where I want the bars in the trunk area now so if it is attached I can do it now instead of later
Liked 1,940 Times in 584 Posts
You only need a weight box if you are going to run loose ballast like shot bags. I see some who have hard weights mounted with a large stud and nut to the frame rail. You are only allowed 100 lbs. of removable ballast
Mike Pearson 2485 SS |
100 lbs "removable"... So in theory if the car finished up light I could weld in say a 200 pound steel plate to get close then fine tune with lead, that sound right? I like the idea of bolting in hard weights and not a box. Learning
Liked 311 Times in 175 Posts
The "trick" is to build your combo as light as you can and then add weight in strategic places. If you place thick steel flat bar plates to a frame structure with two 1/2" bolts and tack weld the end of the nut, then this is not considered removable ballast. Add a weight box to fine adjust for different scales and your set.
