Liked 68 Times in 22 Posts
what tension oil ring is good for a lt1 350 stocker motor?
Liked 7,984 Times in 1,525 Posts
Low
I am no pro, but have 6 lb pull in my SS LT1 right now. Have had as low as 4.5 lbs, but it left a blue cloud on the starting line. Never dyno tested both ways, but ran the same times both ways.
Ed Wright 4156 SS/JA |
Liked 18 Times in 10 Posts
Go with a Napier second ring and a 7 to 9 pound oil rings.
Thanks Ed. Really don't want a lot of smoke. Was thinking about a 11-12 pound package. What's your opinion? What is to much that it will really put to much drag? Thanks for your help.
Liked 99 Times in 49 Posts
What Carl said
I use a Napier with 6 lbs. Dry as a bone.
Liked 10,759 Times in 2,236 Posts
What is the correct procedure to check drag from the ring package? Cylinder vertical or horizontal, dry cylinder wall or lubrication on the wall, if lubricated with what and how much, just piston with pin and oil ring or is the rod on it too. Is it the breakaway number or the dynamic pull reading?
Liked 1,940 Times in 584 Posts
This is what I run. I am not the fastest but run well. I ran some 9 lb rings and they were OK too.
Mike Pearson 2485 SS |
Liked 68 Times in 41 Posts
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
