Old 01-24-2017, 11:32 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default "Super 10" Super stock heads & intake & cam & carb
Super Stock racers,
The idea is being considered to change engine combinations with my Super 10. The heads are Gary Hettler design with about 15 runs since new. All parts are new, valves, springs, retainers, seals, locks. The casting number is 041, this is the 327 or 350 head with 1.94 x 1.50 valves. They are fully worked, latest design, Hettler heads.
The heads are fitted with T & D shaft rockers but I may retain those, depends on a racers needs.
In addition, the intake is a Victor E, also fully worked and matched to the heads by Hettler.
*Two Heads complete, race-ready = $6,100.00
*One Victor E for above heads = $400.00
*T & D set with 1.7 rockers = $900.00
*Comp Cams specific grind per Hettler = $300.00 [cam is BBC journals]
*Quick Fuel carb, NHRA replacement for 300/327, tested and corrected on BLP flow bench.= $600.00
Contact me if interested. Thanks, Larry Woodfin
Larry Woodfin 471W
