Old 01-22-2017, 09:29 PM   #1
rdlong1961
rdlong1961's Avatar
Liked 5 Times in 1 Post
Default Spare Engine 350 cu inch 255/280
010 block .030 over std bore
GM cast crank offset .015 mains.010 rods .030 (Glen Culp)
GM Performance Rods (pink replacement)
Venolia Forged 2813 Std ring grooves
Dykes .031 Top ring w/spacer C&A cutback 2nd ring Low Tension oil ring
Lunati 60199 390/410 264/272 @ .050
Trend hydraulic low travel lifters EC842GM-2H
Crane nitrided stamped steel rockers 1.50 ratio
Rollmaster timing chain and gear set
441 Heads by Griffith / Kell
GM intake 3927184 by Griffith / Kell Engine*$4583.60 new
TH350 by Carl Rossler reverse pattern 2.75 low torrington tail *$2387.52 new
041x heads by Woodro Josey Manley valves K-Motion springs & retainers
3927184 intake manifold by Woodro Josey *$1452.59 set new
ATI TH200 Metric Converter #A4245107 8” Treemaster *$790.28 new
GM Performance Bow-Tie block 1085047 4-bolt nodular iron caps $1500.00
* prices new are negotiable/ shipping not included / delivery in Ohio possible
Contact Info:
Classracer-pm / Text only 419-586-673two / long-rodney@thewavz.com
rdlong1961 is offline   Reply With Quote
