Old 01-21-2017, 06:12 PM   #1
jerry harris
Default 904 Trans for Chevy
Chrysler 904 trans for Chevy has chevy bolt pattern built by Allison A&A
Transmission aluminum drums internally modified case has reverse pattern
valve body with trans brake with clean neutral at rear. comes with PTC
7 " converter must use 1/4 " motor plate & small flywheel 157 tooth.
5 1/4 mile runs since freshened. Deep aluminum pan. $2200.00 plus
shipping.2.45 - 1.45 - 1 gear ratio Have 2.75 gear set that goes with trans. Also have Turbo-Action air operated shifter modified by ACD
for above trans $400. more info 256-310-1745
Jerry Harris 2111 SS
jerry harris is offline   Reply With Quote
