Old 01-17-2017, 11:28 AM   #1
John Kissel
Liked 230 Times in 94 Posts
Default GM truck air bag system
We have a 2006 TrailBlazer SS with rear air bags. Why GM didn't use a nice simple system like they had in GMC Generals or like Peterbilt or Kenworth uses makes no sense. The truck will empty the bags every so often for no certain reason. It could sit for 4 hrs. or 24 hrs. 8* out or 48* seems to make no difference. Reading the confusing big words in the service manual just leaves me confused.Spraying the leveling devices with Silikroil helps, but they are only electric and have no air going to them. The truck has 175k on it and I feel if I was to spray something in the air intake of the compressor it might upset things as it will fill up when started and ride fine. Thanks in advance, John Kissel K242.
John Kissel is offline   Reply With Quote
Old 01-17-2017, 12:02 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: GM truck air bag system
The air bags have small leaks rubber is cracked or dry rotted due to age and mileage. Replace them with Arnott bags and maybe new shocks while you are at it 2-3 hours repair about $90 for the bags and whatever you want to spend on shocks we used Bilsteins total of about $ 250-300 depending on what you do and where you buy your parts. FE. D387
