Old 01-08-2017, 07:38 PM   #1
KG-CMF
Default Kilgore trans, coan converters, misc parts
-John Kilgore th400 2.33/ 1.48, greiner valve body- p-r/n-1-2-3-n, moroso pan w/ heater, csr sheild, turbo spline 35 runs since freshening. $3000.
-Coan 7 inch- txb2817d,turbo spline, approx 30 runs, stalled around 9000 324 cu.in. Engine- $650
-coan 7 inch- tx3017d,turbo spline, approx 5 runs,stalled around 8800 324 cu.in. Engine- $500
both converters used only on above trans, converters and trans where purchased new.
-TH400 Deep cast aluminum pan- $60
- 8 NEW- PSI, DR1250 valve springs, 3 are ML series $100
- 8 USED jesel .937 body/ .850 roller wheel/ .150 keyway, straight lifter- $200
- 8 USED jesel .937 body/ .850 roller wheel/ .150 keyway, .050 offset lifter- $200
- USED approx. 35 runs MGP rods 5.56 x .927 pin x 1.88- $150
- FELPRO 1641 metal/rubber cork splayed valve cover gasket
- Mr.G 104 splayed intake-
all prices negotiable
kgotie@twcny.rr.com - 3155421195
Kevin Gotie
KG-CMF is offline   Reply With Quote
