Liked 473 Times in 83 Posts
Rossler Powerglide / Shifter Setup For Sale:
SFI certified Dedenbear case (no need for a shield) 2.08 Low Gear (3 seasons since replaced) 2 seasons on new ATI Drum/Band 55 Runs since serviced and freshened this spring Deep Moroso Pan Rossler Trans Brake Forward valve body Turbo Action Forward Pattern 2 Speed Shifter(3 Speed adaptable with removing a tab) Shifter has line lock button attached Dedenbear RPM Shift Module for 1-2 shift Dedenbear Electric Shift Solenoid Everything you need to drop the trans, shifter, and module in the car and go racing! Make Offer! New setup is in the car, no reasonable offer will be refused! Call Ron at 320-248-5402
Brian Zenzen SS 5404 STK 5401 |
