Old 12-15-2016, 12:21 PM   #1
Comp 798
Comp 798's Avatar
Default Lt1 short block,transmission,converter,headers,3rd member +
LT1 Super Stock Short Block:
All New Bowtie block, Crank, Rods, Pistons, Rings, Bearings, Cam and Lifters. 59 passes on everything since new. Perfect condition. Call for specific details $7500.00
PRO TRANS TH350:
2.45 1.51 (E-2). Absolutely the best parts available. Perfect for Super Stock or Comp includes adj. trans brake. $7150.00 new. Only 16 passes, will sell for $5950.00.
New A-1 Converter with 16 passes $1200.00 new, will sell for $650.00.
Mark Williams 3rd member Pro Stock Assembly:
Aluminum thru-bolt case (3.812" bore), 40-spline aluminum spool, steel MW 1350-series pinion yoke, ball bearing pinion support 5.67 9" Pro gear. $2275.00 new. Only 16 passes $1650.00
Headers for LS1 Super Stock motor. Was in 2005 Cavalier. $3600.00 new. Only 16 passes $1650.00.
Everything has 16 passes from new except the short block and in perfect condition. They were in a 2005 Cavalier GT car with an LS1 that was changed to an LT1 with a new PRO TRANS TH350 and converter that works with that combination.
Also have motor plates, used tires, shocks, more.
Call Bret for details:
419-348-5169
419-299-3315
Sam Tufano
Comp 798 is offline   Reply With Quote
