Old 11-19-2016, 01:45 AM   #1
FastBuick
Default Various Race Parts
Items For Sale:
Fully Professionally Ported Dart Spread Port BBC Intake Manifold $595
Manley Performance Severe Duty BBC Stainless Steel Exhaust Valves.
11/32" (.3415") Stem Diameter
1.900" Head Diameter
5.422" Overall Length
.250" Tip Length
Full set of 8 valves that are in excellent like new working condition. $169
Comp Cams Hi-Tech Dual Taper .125" Wall Heat Treated One Piece Seamless Chromoly Steel Pushrods
•3/8"-7/16" Dual Taper Diameter, 8.550" Length, .125" Wall Thickness Part# 8219-1 (8 pushrods) $180
•3/8"-7/16" Dual Taper Diameter, 9.300" Length, .125" Wall Thickness
Part# 8249-1 (8 pushrods) $180
Comp Cams Hi-Tech Dual Taper 3/8"-7/16" Diameter .125" Wall Thickness Heat Treated One Piece Seamless Chromoly Steel Pushrods Complete Set of 16 that will fit Big Block Chevy and other engines. Includes part numbers 8219 & 8249 (8.550" length & 9.300" length) $350
Comp Cams Hi-Tech Heat-Treated One Piece Seamless Chromoly Pushrods 3/8" Diameter, .080" Wall, 8.550" Length Part# 7934-1 (8 ea.) $75
Comp Cams Hi-Tech Heat-Treated One Piece Seamless Chromoly Pushrods 3/8" Diameter, .080" Wall, 9.300" Length Part# 7923-1 (8 ea.) $75
Comp Cams Positive Stop PTFE Valve Seals part# 503-16 $20
ARP Ring Gear Bolts Ford 9" Part# 250-3002 $18
ARP Cylinder Head Stud Kit SBC 18 degree Part# 234-4721 $175
Manley Performance ARP 2000 Rod Bolts part# 42390-4 (12 packs of 4 are available, or 3 complete sets of 16) $12.50 per box of 4 or $50 per set of 16
Jesel BBC belts part# 31010
2 available $25 each
JE 52 series wrist pins BBC .990"x2.930" .180" wall thickness $70
RJS Camlock Style 5-Point Harnesses $50
If you have any questions, want more information, or would like some pictures please contact me. You can message me here or text/call 570-510-2811.
Thanks
FastBuick is offline   Reply With Quote
