Old 11-15-2016, 09:02 AM   #1
Charlie Laraia
Default 1984 camaro
1984 Chevy Camaro-Stock suspension.
Clean body. No rust ever.
400 Cubic Inch Small Block Chevy
Dart Little M Block (Billet splayed caps)
Scat super light weight rotating assembly (350 mains-6 inch rods)
SRP flat top pistons
10.4 Compression ratio (Pump Gas)
Air Flow Research 235 Heads
Comp Cams Solid Roller Cam 262/270 duration .690 lift.
Comp cams Roller lifters
Jesel Shaft Rockers
Holley 950 HP Carburetor
Edelbrock Victor intake
Ed Quay 1 7/8 Headers
Moroso oil pan
Magna Fuel fuel system
MSD Distributor and electronics (MSD Digital 6)
MSD Crank trigger
Moroso Vacuum pump
Canton Racing Accusump
ARC switch panel and fuse panel
Autometer tach and gauges
Kirkey aluminum seats mounted on adjustable rails
Turbo 350. ATI reverse pattern manual valve body. 2.75 Low gear.
5000 stall Coan convertor
B&M Pro Ratchet shifter
Ed Quay front cross member
Koni front Struts
Ed Quay bump steer kit and damper.
Mild steel cage and chassis work by Markow Race Cars
Adjustable torque arm
Strange single adjustable rear shocks
Billet Specialties 15X4 Streetlites and Hoosier front tires
Billet Specialties 15X10 Streetlites and Hoosier 9X30 radial slicks
Billet Specialties 15X10 Streetlites and Hoosier 11.50 x 28 Quick Time Pro’s
Moser 9 inch back braced rear.
Strange center section. 4.71 ratio
Moser gun drilled star cut axles
Strange 11 inch rear drum brakes
Stock front brakes
Strange master cylinder
Stock radiator with Electric Fan
Stock and bolt on Harwood 4” fiberglass cowl hood
Runs 10.20 at 130 all day long. (10.15 @ 132. Best). 1.35 60’
Well built, fun to drive and super reliable
Hooks like crazy on 9 inch wide tires
Street legal. (Race during the day, then go to a cruise night).
$24,500 (Could not buy the parts for this amount.)
See pics in Racing Junk ad #182797664
860-614-2252 Charlie
Wethersfield Ct.
Charlie Laraia is offline   Reply With Quote
