Liked 98 Times in 23 Posts
1970 Nova - Super Street - Super Pro ET
10.90 @ 143 mph in Super Street trim Pro Motion built 440 SB Chevy - Built 2016 - 800 HP – Have Dyno Sheets Iron Eagle Block with raised cam tunnel Comp Cams .840 lift Callie crank and rods Brodix 245 spread port heads - T1 valve spacing TD offset rockers Manton Tool Steel push rods SRP coated Gas Ported Pistons Belt drive Vacuum pump Stefs custom oil pan Brand new Hedman 2" to 3 1/3 coated headers Select Performance Power glide with Reid Case. Fresh 2016 Select Converter – Fresh 2016 Products Engineering fuel system bypass regular – New 2016 Mega 450 Digital Delay Box # 1 Throttle Stop, MSD 7AL3 MSD HVC 2 Coil MDS Distributor Moroso Ultra 40 Wires Painless Wiring Dana 60 with 4.88 Ladder bar Strange Disc brakes front and back, QA1 coil overs all around Tubular front arms, 5 passes on brand new rear Hoosier rears Certified 8.50 cage New Simpson belts Optima Batteries Very consistent and dead straight every time. Won Super Street Championship in D1 2014. Jegs Allstar 2015 Complete Turnkey car ready to go racing today. Comes with half drum M5 alcohol, Brand new spare starter, spare MSD Ignition box, two spare Strange calipers and brake pads, gasket set and 4.56 gear set. All fresh beginning of this season Only raced it four times this 2016 season. $25,000. Frank Quarno fquarno@hotmail.com 973-390-3422
Dave Ficacci 1013 STK 1170 SS Last edited by Dave Ficacci; 11-19-2016 at 05:11 PM. |
