Old 08-02-2007, 09:11 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Battery box
I read the NHRA rule book about batteries in the trunk and it
only states that the battery must be secure.
Just what does that mean?
(1) just clamped down and have the bolts go through the trunk floor.
(2) plastic battery box
(3) metal battery box
Just what is correct and safe??
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 08-02-2007, 10:09 PM   #2
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Default Re: Battery box
Phil, not sure where you looked, but on page 227 of the 2007 NHRA Rulebook, it's fairly descriptive. What I did was seal off the trunk behind the rear seat and package shelf with .032 aluminum, and had a battery tray fabricated and bolted to the frame section through the trunk floor with 3/8 bolts. The battery is secured to the battery tray with 2 3/8 threaded rods with a tubular strap along the top of the battery.
Hope this helps.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 08-04-2007, 08:24 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Thumbs up Re: Battery box
Joe;
Am I correct?
If you use a nhra/ihra sanctioning approved "sealed box" vented to the outside, as in the Moroso #74050 or equivalent, you do not have to seal off the trunk behind the rear seat and package shelf?
This type of box must be secured to the car in the same manner as you described.
http://www.moroso.com/catalog/catego...?CatCode=42001
Old 08-04-2007, 06:16 PM   #4
Joe Martens
Bob, as I read it in the rulebook, you are correct. It looks like that Moroso kit comes with everything you need.
