Old 11-07-2016, 12:27 AM   #1
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Default Garage sale
-327 041 Super Stock heads by Heads up!, One head was brand new just done last winter and has less than 50 passes on it paid over $2400 for just the porting & assembly work on this one head, the other is older and has a leak in one intake bowl. 2-heads with valves, springs, retainers. No rockers. I also have another bare head that is matched to these ones that also has a leak. $3,250 for all.
-Used Auto Meter 17 channel data logger. Includes software, download box, 50' download cable, dual axis accelerometer, engine rpm, input shaft rpm sensors, driveshaft rpm with collar for 9" ford rear end, oil pressure with sender, fuel pressure with sender, and 4egt used sensors and 4 older used sensors (2 of the sensors last used were not reading correctly and need to be swapped or replaced), I have the instruction manual, a box of misc extra sensors, pickups, wire extensions and connectors. $599
http://www.racingjunk.com/Gauges-Ins...ta-Logger.html
-Mickey Thompson tires Et street S/S tires. Brand new mounted up and decided they were too tall for the street car I bought them for. $208 each new at JEGS selling the pair for $350
-5 Gallon pail of Valvoline SAE 20w-50 racing oil $100
-SBC 327/250 pistons JE job #580450 8 pistons used and coated / 3 pistons new uncoated. 4.032 bore / .875 pin 2.500 long / .043-.043-3.0mm oil ring. Bare piston weight 412 grams $450
-SBC 327/250 pistons JE job # 243938 8 pistons coated skirts measure 4.060. .043/.043/3.0mm oil ring. Bare piston weight 395 grams $300
-SBC 283 pistons BME job # 38457 13 used pistons total, skirts measure 3.8975 for 3.905 bore. .043 top / .045 2nd ring bare piston weight 358 grams $300
-SBC Block castings
283 3789935 date A43
283 3789935 date B153
327 3782870 date I254 (Marine grade block)
327 3782870 date I214 (Marine grade block)
Call text or email
brad@zaskowskibuilders.com
(616)437-4958
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
