Old 11-04-2016, 05:01 PM   #1
Scott Hamel
Thumbs up 402 Big Block Chevy 1970 L-34 Suffix CTX
Street Performance, Blue Printed, Scott Hamel, Assassin Racing
Correct Block For 1970 M/T Chevelle, Nova, Monte
402 + .030, Steel 6223 Crank, .010/.010 By The Crank Shop, 3/8 Rods, Sealed Power Pistons, 10.3:1
Melling High Volume Oil Pump, Moroso Pump Drive
Closed Chamber Oval Port Heads, New Valves, Guides. Surfaced, Spring Heights Set
Weiand Stealth Intake
Lunati Flat Hydraulic Cam + Springs I.527/224, E.558/230@.050 Jegs Roller Rockers, Dbl. Roller Timing Chain, Torrington Bearing And Cam Button.
This Engine Is Solid, Fresh And Will Provide Thousands Of Miles Of Fun. The Build Is Documented In Pictures
Call For More Info. $3950.00 Price Is Firm. Limited Guarantee
518-674-5748....shamel1@nycap.rr.com
Scott Hamel is offline   Reply With Quote
