Old 07-30-2007, 10:25 PM   #1
mike coates
mike coates's Avatar
Default Moving Sale - Mopar Projects
1965 Valiant: Project vehicle. 2 door sedan. Original 6 cyl. 3 speed on tree. No engine or trans. Stored inside last 3 years. When I bought the car, the previous owner had started some body work, but I think it will need to be redone. Solid car, will need front driver and passenger floor replaced. I think the quarters will need some work also. Remainder very solid. Trunk very good. Frame good also. Glass is good. Trim is fair, but I believe is all there. Interior is rough. Pics available.
$1500 or will trade for 67-69 2 door valiant, cuda or 70 ? 72 swinger of similar condition. Car is located in central southern Michigan. I am moving to Indy, so I can deliver to Indy or in between, within reason, for small fee.
Email at oemsg@aol.com
1991 dodge Dakota project truck. Started to build for stock, but could be run in any class or on street. Solid body and frame. Has dent in passenger door. Bed was removed and frame painted, but it should be touched up. Have original rear, but not installed, springs gone. Cab is stripped except for dash. I have the heater core, but I removed all ducting. Original 4 cyl, 5 speed. The engine and trans is gone. This is what I have to go with the truck. ?91 318 throttle body engine from junk yard, complete pan to TB, less pulleys. 8 ? housing. 5 spoke spindles, calipers from ?88 dakota. Motor mounts for V8. V6 wiring harness, 1991 service manual, bucket seats, fiberglass roll pan to replace rear bumper. Stored inside for last 8 years. Picks available
$2000 or will trade for solid 67-69 2 door valiant, cuda or 70 ? 72 swinger. Truck is located in central, southern Michigan. I am moving to Indy, so I can deliver to Indy or in between, within reason, for small fee.
Thanks,
Mike Coates
3914 D/PS
mike coates is offline   Reply With Quote
