Old 10-11-2016, 12:17 PM   #1
JCChildress
JCChildress's Avatar
Liked 13 Times in 6 Posts
Default St Jude benefit engine raffle
The engine is done that we have built to raffle off for St Jude Childrens Hospital. I'll tell you about the engine, and all parts are brand new:
Dart SHP block
Molnar 3.875 stroke 4340 steel crank
Molnar 6" H-beam rods with ARP 2000 bolts,
Total Seal ringset
Diamond 4.155 bore pistons +11 cc dome
ACL H series main & rod brgs
B&B steel oil pan and pickup
Melling HV oil pump
ATI balancer
Melling oil pump drive
Erson custom roller camshaft
Erson/Morel roller lifters with bushing
Profiler CNC ported 235cc cyl heads ( 23 degree )
Manley severe duty vaves
Manley Nextec valve springs
Jesel Pro Series shaft rockers
3/8 pushrods
Cometic head gaskets
Fel Pro intake and oil pan gaskets
CV Products belt drive
ARP head bolts
Edelbrock Super Victor II intake
MSD billet distributor ( black )
MSD plug wires
Moroso sheet metal valve covers
Custom Bill Pink 950 Holley carb
Meziere water pump
House of Payne Hi-Torque Mini Starter
This engine will come with two 5 gallon pails of VP racing fuel, a MSD 7AL2 box, a $500 gift certificate towards a custom torque converter from Ultimate Converters, two Kowalsky Racing hoodies, and probably a few more items.
The engine made 728 HP on our dyno and 614 ft lbs of torque. This is a good, dependable bracket engine. It has 14.5 to 1 compression ( IT IS NOT A STREET ENGINE )
We will sell 200 tickets for $100. each. You do not have to be present to win and you are responsible for picking the engine up.
Proceeds go to St Jude Childrens Hopsital. Thanks so much to each and every business that donated to this awesome engine.
If you need any tickets, come by or call us (434) 821-6107 or 6109 or look on our facebook page Kowalsky Racing Engines
JCChildress is offline   Reply With Quote
