Old 10-09-2016, 09:51 PM   #1
Mark I
Default 69 Bel Air 2 Door Sedan BB
Been reading the forum for some time, and this is my first post.
Building a 69 Bel Air 2 door sedan, mainly for bracket racing because I could never afford a proper stock class campaign. Right now the car is stock, has a 2bbl 327 and TH350. I removed the greasy 10 bolt last year and installed a 4:11 12 bolt. I have a TH400 core for building. Also have the basics for a decent oval port 454.
Just finishing up a front end rebuild and changeover to power front disc brakes. So first question, I am perplexed as to how to set up and improve the front suspension on this car. I am pretty familiar with the 65-70 b-body front ends and have maintained, rebuilt and aligned many over the years.
What can be done do minimize camber and toe change with front end extension and compression? I put in upper ball joint spacers but the upper a-arm geometry went to heck. Using shim stacks on the upper arms didn't help. I removed them and am back to mostly stock. Will I need to get into cutting and modifying upper arms?
Any expertise or help here would be greatly appreciated.
Thanks!
Mark
Mark I is offline   Reply With Quote
Old 10-09-2016, 10:49 PM   #2
Mark I
Default Re: 69 Bel Air 2 Door Sedan BB
Couple of pics. Looking for a vintage junior stock look.
Name:	12 Bolt Rear 3.10.26.15SM.jpg
ID:	37262   Click image for larger version
ID:	37263   Click image for larger version
Name:	69 Bel Air 8.11.12 2SM.jpg
Old 10-10-2016, 09:03 AM   #3
Bunkster
Liked 43 Times in 10 Posts
Scroll down a bit in this thread and you’ll find a 69 like you’re building. This one used a 350/255 motor and went 13.30s or so...in 1970.
http://www.classracer.com/classforum...d.php?p=353131
Bunkster is offline   Reply With Quote
Old 11-09-2016, 10:02 PM   #4
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
Join us on Facebook Jr Stocker. Great looking car.
Old 11-11-2016, 02:27 PM   #5
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Still have my 1969 Impala from 1972
Frame off restoration taking too long.
Still for sale with a Budd Rowe 350/255 engine
D
Old 11-15-2016, 11:24 PM   #6
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Mark, I ran a 1968 Impala 396/325 in I/S Back in 2003-05 only modification on front end was cutting coils 1.5 coils. Never got around to do anything else, but car went straight. , ran high 11's. Finishing up same combo 1965 Impala, same thing except better shocks.
Will Lamprecht
